Upping my towing capacity (Just for chat)
Old 01-14-2016, 06:26 PM
Dutter 2's Avatar
Dutter 2
Dutter 2 is offline
Alrighty maybe I'll just do a Dana 60 in the front and hydroboost and call it good.
Old 01-14-2016, 06:28 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Just a FYI. the Dana 60 gives you ZERO more capacity. It has the same axle rating of 4600lbs that the Dana 50 TTB has
Old 01-14-2016, 06:32 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
you've got the PSD/E4OD/4.10 combo.the highest rated 9th gen pickup towing capacity combo.hook onto her and run 'er.
the hydroboost brake system is a huge upgrade,however that's not needed with a trailer with working brakes.where the hydroboost shines is when just running with the truck with a heavy load on.
Old 01-14-2016, 07:27 PM
Dutter 2's Avatar
Dutter 2
Dutter 2 is offline
Ok maybe so but I'm pretty sure the rotor size is bigger. And yep I got good trailer brakes but I still would like to have the security of hydroboost with my bigger tires. And what parts would the consist of ? Power steering pump, lines and booster. Anything else ?
Old 01-14-2016, 07:39 PM
FORDF250HDXLT
oh your preaching to the choir as to whether or not to upgrade.
ok,hydroboost doesn't change the brakes.it simply changes how much pressure the brakes receive via a different method from vacuum assist to hydraulic assist.
everything you need to know can be found here.read the whole thread to find info on the brake pedal etc.
https://www.ford-trucks.com/forums/1...st-brakes.html
Old 01-14-2016, 07:56 PM
mrollings53's Avatar
mrollings53
mrollings53 is offline
What's your hitch rated at? You can upgrade everything else, but it's kind of pointless when the trailer rips the receiver off the frame.
Old 01-14-2016, 08:13 PM
Dutter 2's Avatar
Dutter 2
Dutter 2 is offline
Ok thanks I'll check it out. I know how the hole system works just wondering what parts I'll need to covert it. And maybe get luck at the junk yard 😁
Old 01-14-2016, 08:14 PM
Dutter 2's Avatar
Dutter 2
Dutter 2 is offline
And the bigger trailer will be a gooseneck
Old 01-14-2016, 09:29 PM
DeathRangerofDeath's Avatar
DeathRangerofDeath
DeathRangerofDeath is offline
Originally Posted by Diesel_Brad
You are FINE to tow a 11,000b trailer.
the GVW of 8,800lbs is to the TRUCK alone(what is sitting on the trucks 4 tires), not counting the trailer
the GCWR(gross COMBINED weight rating) is 20,000lbs, aka the truck, trailer and load
Just to expound on this, 20k GCVW is combined for everything. 8800 GVW is the truck, plus any cargo(in the truck), plus the TOUNGE/PIN WEIGHT of the trailer. So, you can never (legally) exceed the truck exerting 8800LBS through its tires. It's further broken down by axle capacities.
So, in a GN/5th setup, you'd have about 20% of the trailer's weight as tounge/pin weight. That comes directly off your payload capacity and the truck's GVW.
At 11k lbs, that gives you a pin weight of 2200 lbs on the truck.
Also, I'd have to check again, but in my 95's manual, I think the highest tow rating of any of the trucks is 10k.. I have a 95 460 4.10 with a 8800 GVW. I have a payload capacity of like 28xx lbs. I think there was only one combination with a GVCW higher, but it was a diesel, and it lost its advantage in a significantly higher curb weight.
Old 01-14-2016, 09:36 PM
Dutter 2's Avatar
Dutter 2
Dutter 2 is offline
Alrighty thanks. Guess I underestimated my truck
TexasDiesel97
22
09-11-2014 07:21 AM
Shwan_89HD
11-07-2012 10:06 PM
bluefever
08-16-2010 09:24 PM
BMFNTOY
18
04-03-2008 04:34 PM
Shannonm1
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
06-03-2003 07:12 PM
Quick Reply: Upping my towing capacity (Just for chat)
