Will it work ?
01-14-2016, 02:04 PM
on
Will it work ?
Will a 2002 7.3 block accept my 95 heads and injectors,fuel pump and all the accessories and bolt up , work in my 95 f350
01-14-2016, 02:07 PM
I believe you have to switch to electric fuel if you use the 02 block, IIRC it doesn't have the hole for the fuel pump
01-14-2016, 02:10 PM
It has the hole but has a freeze plug, you will have to change cams thou
01-14-2016, 02:15 PM
^^Thanks man.^^ Just couldn't remember...
Shattered
07-24-2015 03:49 PM
drewdole
58
02-19-2010 03:14 PM
Brians97F250Crew
02-16-2010 09:50 PM
Ford Junkie
07-15-2006 07:58 PM
buddythomashou
09-20-2002 11:30 PM
