Windshield Washer Freeze
I have had a 2016 f150 for 1 month. It was -15 degrees last night here in South Dakota and -35 below windchill. My truck had to sit outside. Started it up and it warmed for about 5 minutes and I had no trouble with the washer fluid. This is the fluid the truck came with. Sprayed out like it was 70 degrees.
I still think that the not spraying problem is rain getting into the nozzle and freezing.
But good to know that the stock stuff is good down to -15F. But I prefer the -45F stuff.
Good to know that -15 it was still good. I have not put in new fluid yet in mine.
A few years ago my brother in law had his car serviced right before winter and they added plain water in his tank and it froze up solid. I added a container of rubbing alcohol and we got it thawed out and emptied his tank. IN a pinch that worked out well.
I am going to head out soon and add some new washer fluid. 10 below or so here.
New 2015 F-150 with 3.5 Eco boost. I'm in Southeast Wisconsin. 9 degrees today. I got rid of my standard -20 fluid and replaced it with -35. Keeps freezing up. I went to the dealer and it warmed up in the shop and began working. Within two blocks from the dealer it was froze again. Anyone else haring a problem here.
Never had this before and in mush colder temps here. Dealer is swamped. Told me to call in the morning and maybe they can order new nozzles...
LOL! I scoffed at the cold wimps here in California when I first moved out here from Minnesota... now 45 years ago...
I still tolerate the cold better than most, but I'm not as macho about it any more.
Based on what others have been observing, I think that the windshield washer fluid is not freezing, but there is something, probably frozen precip, that is clogging the spray nozzles.
It's cold 20F but sunny no rain today.. I poured hot water on the nozzles and cowling and hose. They started working again. When out a hour later to check if the front camera washer was working it was but the windshield washers went from a very low stream to nothing while I was checking.. They stopped working while they were working no way rain water got into them.
That was my thinking also.. Till I proved today that that's not what is going on.
Picked up my car and drove cross country thru Wash. Idaho, Montana etc. Froze my *** off the whole way. It takes something out of ya for sure.
#30
Hello. First post.
Hi. I found your group through a search. This is my first post.
This problem, of the freezing nozzles, has been killing me!!! I can not get to the bottom of it!!!
The service manager, at my dealer, even swapped the entire nozzle assembly, from his own truck, into mine. They had been working perfectly, in his truck. Now, they freeze in my truck!
The dealer has no idea what to do next. We have gone through everything that has been stated in this thread. They just freeze, as soon as we thaw them.
This is insane!
Sorry for the rant. Looking for any help I can get.
It's a 2015 F150 s-crew, short box, Lariat, 5.0. Bone stock.
This is insane!
