FORD RANGER XLT 1992
GUYS
HAPPY NEW YEAR TO YOU ALL FROM LONDON UK
I own a ranger 1992..its a very original truck with only 70k miles.
Everything is all fine apart from rain water leak from somewhere which leaves the driver side foot wheel pretty wet..
I have looked every where but can not see any place that would water come through.
Has anyone here had a similar issue with your ranger?
It looks like its somewhere behind the dashboard...i think could be underneath the fresh air grills located by the side of the wipers shaft?
Could someone here give some help?
Many thanks
Many thanks
A couple years ago I stripped everything off my firewall to repair some rust damage where rain water was leaking in. The entire process was photographed and documented here:
https://www.ford-trucks.com/forums/1...st-damage.html It should give you a good idea of places to check. Hope you find the problem.
rdelp
1983 - 2012 Ranger & B-Series
10-01-2009 12:26 AM
mwall
06-08-2003 08:31 PM
