Urgent! Need help! no start missing oil!
hey guys so i have a 2002 7.3l with 229k miles. so im having a big problem now missing oil! my reservoir is empty and my dip stick is reading low, and i just put 16 quarts in yesterday with the new filter! im having a long start issue obviously because i don't have any oil supply! just drove the truck today, ran great been having this issue for the past week. here are the details. i came up from Texas after installing joeys t500 pump, when i arrived to California there was oil everywhere! my pump that joey rebuilt had an issue so he sent me another and bam! runs great no probs, now after about to weeks and about 15 degree temp drop i get hard starting. first time instead of a 2 second start up it took 9 seconds, now it takes anywhere from 9-20 seconds to start! so after my drive today i let it sit for about 3 hours seeing if maybe i had air in the lines from the res not being full, well now i cant get a start at all my res is empty and my dipstick shows little oil, i just replaced the icp. ipr, and eot when i put the first pump in, could this be the lpop? really need all help here guys! thanks !
But most likely the low oil is from refilling hpo rails and hpop reservoir.
ok thats where the mystery comes into play. no oil in my radiator fluid. no oil in my exhaust and the injector o rings i just replaced about 8 thousand miles ago and no issues. the oil vanished in one night. 16 quarts? and that's the second oil change since the second pump installation
There are only a few possibilities which would lend itself to no oil in the HPOP. Leaking, Back Flowing, or LPOP. This is the cause of your long starts as the HPOP needs to fill and, if it empties enough, air.
Top off the Oil. Some need 18 qts, some 15 qts. Don't know why. Many times my personal 250's will have an oil change and read low the following day.
The Manual says to replace the Valve in the Valley. I have never noticed that to be the problem. It usually is limited to either the reservoir or pump. On the other hand So CAL doesn't have a lot of cold start issues.
Get it running and warm. Say 150 F. Turn it off, remove the HPOP Reservoir Inspection Plug on top of the cover and check it to see if it leaks down over a couple hours or is it leaving the pump draining to the Valley.
If you are losing oil it is not the HPOP or LPOP. It is leaking from the engine somewhere, out the exhaust, or someone is draining it. Figure that out first then we can figure out why it is not holding in the HPOP res.
I just chased an issue with my truck not holding fluid on the HPOP res. The front seal on the HPOP had worked it self out and it was leaking from there. There are not really many places for it to go. If its not an internal leak it is either orings or the HPOP seal. I also replaced my LPOP chasing it, I upgraded to the melling lpop. I have a thread on here about my saga. I would post it but I am on my phone. Search for my threads or something about HPOP res leaking. It would be a good read for you. Think there are some good pics.
The truck must have at least 8qts in it, in order to build up enough pressure to open up the injectors so it can run.
What color does the smoke look like coming out of the tail pipe when running? Something may be allowing the truck to suck oil into the cylinders and burning it and sending it out the tail pipe.
been working on diesels for a pretty good amount of time lol dont think im that dullXD yes 2 times 16 quarts, i installed all of the rings with extreme care, and would think i would get the problem when i installed them if not sooner right? this issue started happening about a week and a half after the new hpop, my exhaust is clean other then a small amount of black smoke now and then
