Flat towing F-150 behind a motorhome
Better to get the drive shaft disconnect device.
Best of luck,
Scott
Originally Posted by 2015 Owner's Guide page 267
Four-wheel-down Towing
1. Put the ignition in the on position, but
do not start the engine. If your vehicle
has an ignition key, turn the key to on.
If your vehicle has intelligent access,
press the engine START/STOP button
once without pressing the brake pedal.
2. Press and hold the brake pedal.
3. Rotate the four-wheel drive switch to
2H.
4. Shift the transmission to position N.
5. Rotate the four-wheel drive switch
from 2H to 4L and back to 2H five
times within seven seconds.
2H.
And is 4A like AWD where it turns on 4wd when slip is detected?
I mean, how hard would it be to put something in the settings menu in the center console? Something like "Enable flat towing"; "OK"?
sheesh.
I read through that, and I keep thinking, why, oh why do they encode these weird things through ignition switches, or 4WD controls, etc.?
sheesh.
sheesh.
Stand on one leg, turning in a counter-clockwise direction with the driver's door open and tailgate down, reach in and turn key 3 times on and 2 times off; now spin clockwise and turn key 2 times on and 2 times off; place foot on brake while hopping on other leg. Start the truck and shut-off within 3 seconds. Repeat twice and the transfer case will now be in Neutral.
New to the forum and from what I can gather from everyone's posts on flat towing a 2011 F150 4X4 with manual shift transfer case is:
1. Shift transfer case to neutral
2. Insert ignition key but do not turn it on at all to unlock steering
3. Tow truck
Do I have this correct?
Your thoughts, corrections, suggestions would be greatly appreciated.
Current plan is getting truck this Thursday and having it outfitted 2/10/17 with Blue Ox base plate w/brake system and lights wiring. Recently acquired a class A RV and plan on using the 2011 as my toad and hauling my motorcycle in the bed. If I'm missing something on the flat towing please advise. Thank you.
3. Tow truck
