Waters in the wiring channel on the passenger side..
So having had my truck for 2 months and it coming to VA from CA its probably never seen rain much, especially on the inside! well now it has.
I replaced the carpet a couple of weeks ago and remember it was dry as a bone on the floor and there was nothing but dry old dust on both sides.
I moved the rubber passenger mat the other day and noticed wetness underneath, i then find the carpet to be damp. I took the plastic door plate off and the front kick panel off and pulled the carpet back. There is evidence of water in the wiring channel and under the carpet on the passenger side.
There doesn't look to be any water stains or wetness on the front of the carpet where it goes up towards the front and underneath where the dash wiring etc is is bone dry. There looks to be most of the wetness at the bottom of the seat belt anchor.
Are there any known issues or problem areas where water can leak in on our trucks ?Ive spent an hour looking online and can only find details on 2004 F150's.
Crazy thing is, my 99 Explorer has EXACTLY the same issue! i fixed it by parking it in the garage all the time! unfortunately the F150 is 3" to long!
I'm thinking off taking the carpet out, putting the seat back in and driving it in rain and sitting out in it the next time we have a good downpour! Any help/ideas appreciated.
My truck's lived in the South it's entire life. Actually it ain't ever lived outside of Florida but somehow the cowl managed to rust out and it would leak water thru the rust hole in the firewall during heavy rain. Of course this rusted out the floorboards on the driver's side. Might look for a rust hole in your cowl just on the off chance you have the same problem I did.
ok so i took the seat and the carpet out this morning. My truck is a standard cab with a piece of carpet also on the back of the inside of the truck. this appears to be dry.
Im pretty sure there must be "clues" in the picture of the carpet. Its on both sides of the truck but nothing at all is coming in from the front, under the dash and the carpet at the front is bone dry. i do park the truck on a slight incline, cab facing upwards.
It looks to me like water is coming in somewhere by the lower seat belt anchors so I'm thinking it may indeed be a seam on the top of the doors/drip rail. It does appear to be both side too! we have a dry weekend coming along so I'm gonna let everything dry out then hit it with the hose over the weekend in various places and watch what happens inside.
Water is all around the outside edge to the back and sides, as you can see. I'm presuming it sloshes up from the rear towards the front, hence the front edge gets wet. I was thinking maybe the 3rd brake light gasket as someone said above or the rear window/seal.
So i took all the plastic trim out of the cab today, ran the hose over certain parts and took a look inside the cab.
Looks like its the rear window seal on the passenger side, plus the sealer/caulking along the top corner at the end of the drip rail.
Am gonna let it dry out the next few days and have a look around for suitable sealant to put on it, anyone any ideas ?
