CV Axle disassembly ?, outboard side, c-clip?
Hi all,
2003 Expedition, rear CV axles: Inner(plunge) side comes apart for inspection, cleaning, reassemble, but for outer-I can't see a c-clip, and hesitate to pry too hard on one of the *****; do you need to beat the inner race off the shaft to separate? Any help would be appreciated. Thanks.
Success
The outer end of the rear CV axles can be separated. The shaft has a 1/32 or a 1/16" of in and out movement, between it and the inner race. On the outboard end of the half-shaft is a small-diameter c-clip. A couple of light taps on the inner race and the shaft can be removed, and the joint rebuilt. I'll put some miles on my axles, and if I have troubles I'll re-post. Thanks.
Ken Tanguay
02-26-2017 07:20 AM
