too much boost
Old 12-26-2015, 08:48 PM
imjwm's Avatar
imjwm
imjwm is offline
too much boost
I got a 95 7.3 powerstroke and i had an intake exhaust and ts performance chip then recently i put stage 1 injectors in it and now i can push a lot more boost and easily get over 30 psi. is there a waste gate or something i can put on the turbo to keep the boost under 30 psi?
Old 12-26-2015, 08:53 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
Why do you want to limit the boost?
Old 12-26-2015, 08:59 PM
fordpride's Avatar
fordpride
fordpride is offline
Your safe on the stock turbo and head bolts up to 35-38psi.
With stageI's you won't see more than 35ish psi
z31freakify's Avatar
z31freakify
z31freakify is offline
Received 1,192 Likes on 818 Posts
These engines thrive on boost, why limit it as long as you dont stay above 32psi for long periods of time(towing on steep grades) you will be find and thats with a stock turbo, aftermarket is a whole different can of worms.
Old 12-26-2015, 11:03 PM
fordman67's Avatar
fordman67
fordman67 is offline
Limit boost? Nooooo
Old 12-27-2015, 12:56 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
MOOSE_MACHINE is offline
Just watch your egts.
Old 01-04-2016, 01:54 PM
imjwm's Avatar
imjwm
imjwm is offline
I've hit 35psi and my transmission was slipping and now i'm putting a stage 1 trans in it and i don't have money for an other turbo so i'm wanting to save it so I thought it might be a good idea to do something to keep myself from pushing it to the max.
Old 01-04-2016, 01:58 PM
MOOSE_MACHINE
Then I would recommend getting your tuner to dial down your tunes. Or at least a couple of them anyway
Old 01-05-2016, 02:14 PM
Talyn's Avatar
Talyn
Talyn is offline
Turbo and boost is not the issue.
It's the transmission that is your weak point. =)
Yes, its hard to have throttle control, we understand.
All of us here do.
Old 01-05-2016, 04:01 PM
fordman67's Avatar
fordman67
I think he got a better trans but now instead worried about thrashing his stock turbo ???
If I read it correctly anyway ?!?!
Old 01-05-2016, 09:10 PM
rolsmojave3's Avatar
rolsmojave3
rolsmojave3 is offline
I ran a stock turbo up to 40psi just about everytime I drove my truck for 10k miles and it finally popped. That and the passenger head started weeping from the headgasket.
Strictly for your reference. And so you can prepare financially.
Old 01-05-2016, 09:55 PM
fordman67's Avatar
fordman67
Head studs before or after?
Old 01-06-2016, 08:29 AM
rolsmojave3
Headstuds after.
I have roughly 5 driveable trucks, so it wasn't a big deal to see how long I could make it before it went south. It's under the knife right now getting new bottom end bearings and main studs, head studs, HPOP, Irate S369, Irate fuel system and the heads inspected.
Old 02-06-2016, 02:28 PM
imjwm's Avatar
imjwm
imjwm is offline
I have a rebuilt stage one transmission in it now but so the transmission is not a problem any more and my boost still goes up fast but only on the last two settings on the tuner. I'm just keep my eye on it when i have it on those settings.
Old 02-06-2016, 02:41 PM
z31freakify
? Your saying you don't want more boost? Or are you confusing boost with egt? Im at lost when you say you dont want more boost. Custom tuning will help, or leave the setting on stock. Who did the tunes?
Quick Reply: too much boost
