headlight switch, 6v on 12v?
The difference is the rheostat within the switch for dimming the dash lights- use a 6 volt switch on 12 and it will melt. You can bypass this feature & use the 6 volt switch by wiring the dash lights directly to another hot post on the switch. - you will have no control over brightness that's all.
Jeff
52 F3
Jeff
52 F3
Got you...I just went through this with my '49 flathead.
three different types of voltage reducers are needed in the converson:
1) you need a ballast resistor for the ignition
2) you need a voltage reducer for the accessories (heater, radio, etc)
3) you need a voltage reducer for the gauges (runtz is the most popular.
All three are different, especially the vr's for the guages and the accessories. It took me a while to get it all squared away andwish I would have had someone else do it, but then I would hae never learned.
being that yours has a reostat, getting a 12vdc headlight switch is the right move. You should be home free...
The concesus appears to be 50/50 on the horn...half feel it is ok to run 12v and the other recommend running 6v.
Personally, I would pick up another voltage reducer rather then chance burining up the relay and horn.
you can get a tranistorized voltage reducer from Radio Shack (7806 or 7805) for $1.50. It has great performance and auto-shutdown.
For the money you cant beat them, there a piece of cake to install. The have three terminals (input, ground & output). you can skip the ground and I frget to mention that you shouldget a heatsink also (another $1.50).
All you need is a soldering gun to solder wire to the terminals and you on the way.
Apparantly they have their own part number fo an otherwisw worldwide standard part number...its Catalog Number: 276-1770 and located at:
http://www.radioshack.com/product.as...Fid=276%2D1770
