Oil leak when cold. What is this?
Old 12-20-2015, 08:24 AM
Lliamspop's Avatar
Lliamspop
Lliamspop is offline
I'm having an oil leak when I first crack my truck up in the morning. After its warm it stops. I have a 95 2wd f250 7.3 powerstroke. Any clue as to what this part is.
You can see where the oil is coming from in the pic. Thanks in advance for any help.
Oil leak
Old 12-20-2015, 08:29 AM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
That's your oil cooler, needs new O rings.
Old 12-21-2015, 08:10 AM
Buck Dharma Fan's Avatar
Buck Dharma Fan
Buck Dharma Fan is offline
Yep..................... what he said ! Very common with these. Replaced mine at 285,000 mi.
Old 12-21-2015, 09:30 AM
oldbird1965
I would have to go look but I believe there is a write-up in the stickies on how to do it.
Old 12-21-2015, 10:01 AM
DZL JIM's Avatar
DZL JIM
DZL JIM is offline
PREMIUM SPONSOR
If you are in a pinch and can't get them replaced right away, plug your truck in over night. The warm coolant often will soften the O-rings and allow them to seal.
This pops up every Fall/Winter as the O-rings get old, hard, and brittle.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old 12-21-2015, 10:18 AM
nossliw's Avatar
nossliw
nossliw is offline
Oil leak
Here is a link to the parts.... Oil Cooler Seal Kit - Ford 7.3L Powerstroke
replace your gaskets while you are at it. When the rings are crispy, usually your gaskets follow shortly. Much easier to put together out of the truck and not pinch a ring.
Old 12-22-2015, 09:08 PM
BBslider001's Avatar
BBslider001
BBslider001 is offline
All of the above and take that Fram POS filter off if there for crying out loud!! Motorcraft, WIX, or Napa only!
Old 12-22-2015, 09:33 PM
oldbird1965
Put any piece of crap on there you want if your running a FS2500 bypass filter!
Old 12-22-2015, 11:10 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
MOOSE_MACHINE is offline
You have a write up on that system Glenn?
Old 12-23-2015, 08:11 AM
z31freakify's Avatar
z31freakify
z31freakify is offline
Received 1,188 Likes on 816 Posts
When the Mule was a fleet truck it used every kind of filter with no problem, but the oil got changed every 4k. But do listen to this guys all the filters mentioned for better filtering, I followed these guys advice and ever since nothing but fl-1995 on my Mule and my Excursion fl-820s
Old 12-23-2015, 08:34 AM
oldbird1965
FS-2500 Bypass Oil Filter System I bought this system seven years ago and have transferred it from the mule to the mare and now the OX.
Old 12-23-2015, 10:50 AM
nossliw's Avatar
nossliw
nossliw is offline
I still would not put a FRAM on there! I have seen a half dozen FRAMs implode the wire mesh, One on a 7.3, one on a 24V, and the rest were on German cartridge filters not meant to have FRAM chit in there... Get rid of it or start saving monthly for a new crank and block machine work...
Old 12-23-2015, 12:28 PM
oldbird1965
Didn't know that Nick, good to know. I have one of those big Donaldson on now.
Old 12-23-2015, 12:42 PM
nossliw's Avatar
nossliw
nossliw is offline
Yeah me too, used up all the black ones I think they are onto the Big Blues...different color is all. Excellent filter!
Old 12-23-2015, 03:57 PM
427 fordman's Avatar
427 fordman
427 fordman is offline
Ya, I wouldn't put a fram on your lawnmower! All motorcraft for me. Race cars get motorcraft racing filters too. I've heard AND seen too many bad things with fram filters.
Quick Reply: Oil leak when cold. What is this?
