cab corner patch panel
Hey guys ,
I'm planing on replacing the cab corners. The p.o gave me them my question is do I have to use the whole patch panel or can I cut it and just use the bottom half to patch the lower half,I circled what I'm talking about...
Also in the second pic there is a lip that folds over the door sil and my patch panel does not have this lip. Is it necessary to have the lip
Thanks dan
The part i circled os what im talkin bout
The lip i was talking about is in blue
Thanks dan
You don't have to use any more of the patch piece than you have to. The smaller the better, imho. Just be sure that you use enough to remove all the offending rusted metal so it doesn't come back to bite you later.
The 'lip' is where the factory cab back panel wrapped around and was spot welded into the door jamb. If your patch doesn't wrap around, you'll need to leave the door jamb part alone and cut/patch on the outside skin. You'll want to butt weld it the same as the rest of the corner patch. It looks like someone already tried to cut the spot welds in the jamb. You'll want to reweld those and dress them back flat again.
Hey guys ,
Thanks dan
Thanks dan
Use as much as you need. I stayed out of the dished or indented part to make it easier.
You might take a look, starting at post #50 on my install of cab corners. I only used what I needed to get to solid metal.
Another 55 F100 build-Long Term - Page 3 - The Garage Journal Board
It is always good practice to keep your patch panel as small as possible, replace only the damaged metal where possible. Here is a small patch I did on a 56 F100...I like to leave the cab mount bolt access in place where possible. Any portion of the body that has a seam or bend provides a lot of support to hold the metal in place and prevent warpage.
MR KROGOTH
05-03-2019 06:54 PM
clintonvillian
03-26-2014 03:28 PM
jm ray
02-08-2013 10:11 AM
rdemilt
01-24-2009 03:57 PM
Randy Jack
06-12-2006 04:41 PM
