1977 ford f100 lowered
Old 12-16-2015, 09:27 PM
dmilob12's Avatar
dmilob12
dmilob12 is offline
Exclamation 1977 ford f100 lowered
hi ya'll im im looking for some ideas on lowering my 1977 ford f100 i want to go air ride suspension any one have some ideas that would be great thanks
Old 12-17-2015, 01:56 AM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Links on lowering in the tech info compilation linked in my sig.
Air ride? Buy a universal kit and get to customizing and fabrication. Easy, right?
Old 12-17-2015, 02:30 AM
AK FORD GUY's Avatar
AK FORD GUY
AK FORD GUY is offline
Old 12-17-2015, 06:47 AM
dmilob12's Avatar
dmilob12
dmilob12 is offline
Well should I go with a 4 link system or a 3 link and how should I set it up. I have a few ideas Im just not sure if it will work. I just don't want to do everything then finish and find out its not going to work
Old 12-17-2015, 10:23 AM
TheMonson's Avatar
TheMonson
TheMonson is offline
Old 12-17-2015, 05:34 PM
dmilob12's Avatar
dmilob12
dmilob12 is offline
thanks for the ideas and how much work was it to put the crown vic front suspension on?
Old 12-17-2015, 05:43 PM
TheMonson's Avatar
TheMonson
There are quite a few threads for that floating around and some stuff on YouTube. For instance:
https://www.ford-trucks.com/forums/1...-vic-swap.html
You would probably be doing yourself a big favor learning how to use the forum search and a little Google-fu. The requisite fab skills go without saying.
Old 12-17-2015, 07:55 PM
dmilob12's Avatar
dmilob12
dmilob12 is offline
Yeah I'm not very good at this computer stuff. This is the first time I have used and been on a forum. But I do appreciate you help man.
Old 12-18-2015, 06:52 AM
TheMonson's Avatar
TheMonson
To get you started, go to https://www.google.com
Type in your search query.
At the end of the query, type in site:ford-trucks.com
As an example if you were searching for your thread title, you would type this into the Google search box
1977 ford f100 lowered site:ford-trucks.com
Which will return something like this - https://www.google.com/?gws_rd=ssl#q...ord-trucks.com
FYI you can do that with any website, not just this one.
Sometimes the forum search function can be a little tricky to learn but it has a lot of value if you take the time.
Old 12-18-2015, 09:26 AM
HIO Silver's Avatar
HIO Silver
There are several CV swaps in the tech info compilation linked thru my sig.
Use it.
Old 12-18-2015, 07:25 PM
dmilob12's Avatar
dmilob12
dmilob12 is offline
thanks man. i have a lot to think about on what i want to do to the front. but i definitely going to do the 4 link system in the back. i just got done taking the back rear out and some rivets cleaning up the frame to paint it tomorrow
sniper05
08-19-2015 12:41 PM
fire3110
05-30-2008 10:13 PM
DEMON1300R
11-19-2007 09:59 AM
385seriesHemi
10-01-2007 09:29 PM
ford truck guy
02-01-2006 05:32 PM
Quick Reply: 1977 ford f100 lowered
