1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2010 f250 super duty vacuum solenoid not getting electricity
Old 12-12-2015, 06:02 PM
Chris82458's Avatar
Chris82458
Chris82458 is offline
Trailering
Question 2010 f250 super duty vacuum solenoid not getting electricity
I have a 2010 f 250 super-duty and i cannot get vacuum past the solenoid mounted on top of the radiator. Ford has given me nothing but bad advice. I know i have a vacuum leak after the solenoid and need to replace the lines going to the two hubs but when i switch on the 4wd and hook up a vacuum gauge the vacuum is good up to the solenoid about 12 inches. i constantly have 12 volts going to the center lead but nothing else in the other two leads either in 4 high, 4 low, or 2wd. Am I missing something here? shouldn't there be a voltage change when i turn the switch to 4wd to actuate the vacuum solenoid to let the vacuum pass thru the solenoid? I have tried replacing the solenoid but that did not help.Also should i buy the vacuum line from ford at $148.00 or use rubber vacuum line and make at down to the hubs?
Thanks for any help I can get Chris
Old 12-13-2015, 10:14 AM
sxrfun's Avatar
sxrfun
sxrfun is offline
Once you switch the **** to 4 hi...the vacuum is only applied to the hubs for a short period of time, 20 seconds or so I think. How soon after switching the **** are you checking for vacuum post solenoid?
Old 12-14-2015, 04:51 PM
Chris82458's Avatar
Chris82458
Trailering
I had the vacuum gauge hooked up went into the cab turned the **** and went to the front of the cab and there was no vacuum. like i said earlier I do not think I am getting electrical power to the solenoid. When I turn the **** the 4wd light comes on if the hubs are locked manually it will shift the transfer case into 4wd, but I see no electrical change at the vacuum solenoid. nor do I ever get any vacuum thru the solenoid.
Thanks Chris
Old 12-16-2015, 10:10 AM
f250mtnbikr's Avatar
f250mtnbikr
f250mtnbikr is offline
Thanks Chris
Chris, I have included part of the wiring diagram for my 2009, and I think your 2010 would be the same.
Pin 2 is +12V which comes from fuse 35 in the SJB at the passenger footrest. Pin 1 is for locking the hubs, and Pin 3 is unlock. These signals come from the 4X4 module and I would assume each goes to ground when activated.
According to the manual, each ground is only present for a short period of time (50 seconds to lock, and only 15 secs for unlock). During either time, some vacuum (5-9in.) will be present to the hubs.
Hope this helps. Good luck in troubleshooting.
Tom
Old 12-16-2015, 01:25 PM
Chris82458's Avatar
Chris82458
Trailering
Thanks Tom
I will check it out I appreciate your feedback.
Chris
59CRL
02-01-2018 09:11 PM
rock2610d
06-04-2017 04:39 PM
HearseDriver
10-15-2015 05:24 PM
iron1951
10-17-2012 10:05 AM
mackstruck
02-26-2010 11:22 AM
Quick Reply: 2010 f250 super duty vacuum solenoid not getting electricity
