thoughts on dually trucks?
on
I am considering a dually to replace my current F250. I recently bought a 4000lb arctic fox slide in camper to replace my much lighter older camper. I had to add airbags to my F250 and it carries the big camper ok but I am over the legal rear axle weight and I do have to pay attention while driving or it can get "twitchy" at highway speeds. I drive a company truck full time so the truck will only see about 4000 miles a year as my camping and hunting rig. What pros and cons can I expect?
The con is daily driving due to width/lenth. It was the only thing that I didn't care for. We had a lance on ours and it was so sweet for the camper. The truck handled the camper so well, I had none of that swaying/unstable feeling. Big campers need a dually IMO. I have a friend w/a 2015 F350 srw that gets by w/a arctic fox that is 3500 dry. He would rather have the dually but drives his truck daily for work. You won't regret a dually for that camper, plus its not your daily driver. Here's a pic of what I did with direct bolt on 19.5's.
I towed a very large slide in camper for years with my dually. Never appreciated the dually until I sold it and bought a single rear wheel truck. Long story short, I sold my camper for a smaller one because it sucked bad hauling it around compared to the dually! Its hard to park either of the trucks, so the only draw back I ever saw was when I had to buy tires! If its a big heavy camper, no questions about it, you want a dually!
With a backup camera on my dually ('04 Sierra 3500 Cab&Chassis Flatbed), I can park better than I can with my F150 extended cab longbox. Sure I can't get in the narrow spots, but I can get nice and close without touching lightposts, signs, vehicles.
Best investment I've made for the truck.
If you need it for a big slide in or 5th wheel, and it sounds like you do with a 4K camper, then you should go for it. Just be aware of its limitations that the others have posted. I didn't buy one simply because it wouldn't fit my garage space - and really haven't felt I needed one with my truck and long/fairly heavy trailer combo.
Why not first give your SRW and camper a test run first before spending lots of money - it may work just fine.
-tire rotation is a challenge
-it is rare that you will not need "the speacial tool" to remove the inner wheels
-the weight class may change your inspection requirements...especially with emmissions
-becareful about winding up with a deisel, went from 08 V10 to 2010 6.4L and I am starting to wonder what i was thinking....like the truck...hate the issues around ford deisel's right now.
-make sure the truck as antisway bars in front and back...not all do
-a 4.X rear end would be a plus
-there are differences with 99-04 and 05-pres dually rim stud spacing....so watch out for that.
-a dually on 17's rides very well, 18's seem a little bouncy to me
-I think the brake rotors got bigger in 08...check into that
-the wider truck is a little more difficult to drive in metro areas and narrow bridges....folks in other lanes seem leary of trying to pass me.
-mud flaps in the front a must or your going to be spray debris all over your rear fenders
Is there a lift on that truck?
I definitely want to look into 19.5" wheels as I'm burning through tires way to fast. Plus I like the look better.
To the OP I love knowing the fact that my dually can handle the loads I put on it much better than a SRW could or should. Stable as can be. I don't own a slide in camper but tow a 14k dump and often load my truck bed in addition. The F250 I had would have bulging tires, severe squat, and be very squirrelly.
on
What are the specs on those wheels and tires? (Make/size)
937 - Kumho Tire USA, Inc.
An 8" lift is going to **** away any benefit of a dually. I hope you're considering putting it back to stock if you got that route.
That said I love my dually. I don't "need" it for my trailer, but my trailer rides level with plenty of bed rail clearance I wouldn't have with a SRW. I'll drive it anywhere, the length is more of a challenge than the width in reality. Mine is not a DD, but I wouldn't hesitate to use it as one. 6 17" tires VS 4 20's comes out to pretty much a wash stock for stock.
on
The 8" lift is a bit much but I would leave it in. Its also rolling on 38s but I would swap them for e rated 35s. My trucks are always lifted and I realize its not the best for a camper rig but its what I do. My current camper truck has a 6" suspension and it really isn't too bad with that big heavy camper. My truck use is 90% off road, even with the camper. It will be a hunting/camping rig with a bit of highway between off road locations.
