1978 - 1996 Big Bronco
1989 motor swap
Old 12-04-2015, 10:36 PM
Dbeckwith's Avatar
Dbeckwith
Dbeckwith is offline
1989 motor swap
Will a 1980 351 bolt up to a 1989 351 set up?
Old 12-05-2015, 06:36 AM
gatorfor88's Avatar
gatorfor88
gatorfor88 is offline
As long as the 80 351 is not a 351m.
Old 12-05-2015, 02:42 PM
Conanski's Avatar
Conanski
Conanski is online now
+1 and if it is swap the whole topend(heads, intake) from the old motor onto that smogger before you drop it in, that will raise CR from Briggs & Stratten(8.3) up to around 9:1 and make this a plug and play swap.
Old 12-23-2015, 02:02 PM
SlinginIron's Avatar
SlinginIron
SlinginIron is offline
+1
There is another post on fsb by Booba5185 that is a good thread showing the replacement of vacuum lines with 4mm silicone hose. It's thick walled hose, and I think I got mine from siliconeintakes.com
Chumbucket
09-15-2007 05:36 AM
REBELboy_327
05-24-2005 08:57 PM
asigalet
05-30-2004 07:38 PM
Quick Reply: 1989 motor swap
