1999 explorer start problem
Yes, another thread on an explorer that occasionally has trouble starting. One cold morning the fuel pump would not operate. When turning the key to run the volts to the pump (with plug disconnected) was 8.6 for a second, then dropped to the 6v range. I took the inertia switch from the firewall and back probed the wire going to the fuel pump, getting 12 volts. I went back to the fuel tank and measured the voltage with the key in run position, and read battery voltage. The car started, and has not failed in 3 days. I know it will quit again. I was thinking of replacing the inertia switch and fuel pump relay. Does anyone have more suggestions?
Based on the low voltage readings you originally measured I'd be looking more for a corroded connection or bad ground.
You mention that you "back probed the wire going to the fuel pump, getting 12 volts." Are you saying that all you did was unscrew the switch from the truck body (while still electrically connected) and then had battery voltage to the pump? If that's the case, I would focus my efforts on the connection to the inertia switch, the nearby ground connection, and any splices for that circuit in the area versus replacing the inertia switch or the fuel pump relay. There's probably a ground screwed to the body in that area that may be prone to corrosion if a drain for the sunroof gets unplugged, if the windshield leaks, or if a heater core leaks.
-Rod
-Rod
-Rod
-Rod
Sounds like you have either a sketchy ground or a corroded wire that needs cleaning and dielectric grease. Every time you turn on the switch, you are essentially forcing a 12v charge to the pump and it will try to jump the gap like a spark plug, but it's always going to look for the path of least resistance, which is why you were only seeing 6v. Look for a bad ground or just clean up the grounds near the tank.
The Tiger
1999 to 2016 Super Duty
09-29-2017 05:51 PM
lamzee
08-26-2006 02:18 PM
sheik
08-02-2001 10:54 AM
