4wd swap
As Shane already stated; no 79 would have a divorced transfercase. Other indications of a highboy would be the low front-most crossmember, ram assist steering, thick front leaf pack (I want to say seven leafs?), 4" narrower rear frame section, 2.5" wide rear leaf springs, in cab fuel tank, and obviously the divorced transfercase. If it is a highboy frame, mounting the bed should be the only tricky part. the rest should be fairly straight-forward. Personally I think Highboys are over-rated. I would rather have a "lowboy" with true power steering, and a married transfercase. Post some pictures of the truck and we will be able to tell you real quick where or not it's actually a 79 frame.
This is not a High Boy, it's either a 1978 or 1979 F250 Ranger Lariat. Lariat's were introduced in 1978.
High Boy: 1967/76 F250 4WD & 1977 F250 4WD before serial number Y20,001 (February 1977).
All High Boys have an in-cab fuel tank, divorced transfer case. 1973/77's use Power Assist P/S.
The High Boy's distance between the inner frame rails behind the cab is 33 1/2."
High Boy available engines: 1967: 240/300 I-6 & 352 2V / 1968/74: 240/300 I-6 & 360 2V / 1975/76: 300 I-6 & 360 2V / 1977: 300 I-6 & 351M/400.
Would it be easier to swap everything under the Frame or do a body swap?
You can't just swap the running gear. For one, the 4x4s use a leaf spring front suspension while the 2wds are coils, so you'll have to fabricate all the hangers, shackles, crossmembers, linkages, modify the steering, etc. So unless you are a GREAT fabricator this is way more work than it's worth. It is NOT a bolt in swap! As we've said several times now, it will be MUCH easier to swap over the body. Bodies should swap with very minimal fabricating. All you might need to do is modify the trans tunnel. The rest is essentially bolting everything together. You'll probably want to have a torch. There is sure to be a bunch of rusty bolts that will give you trouble.
