new AE. now I got questions
My truck started running rough. So I ordered the AE. Now I'm doing a few test. First I cleared all my codes.
First is the cylinder contribution test. I have 3 codes on it. P1464, p0281, and p0541.
What does the cylinder 7 injector circuit contribution / balance fault mean??
Koeo test shows p0605, and p1277 also pointing at cylinder 7 high to low side open.
The koer switch I have a p1211
Buzz test I got a p1277
At idle my icp is between 835 and 870 psi, 11.33% duty cycle
My dtc codes are p1316, and p0541.
To much for my little brain here.
I'm guessing I have a issue with cylinder 7.
Somebody help me out on this
on
Now that you have recorded everything with a freshly code cleared PCM, pull the chip/F5 and run all the tests again to see what remains or if a new code is present.
Most will agree that it is better to diagnose problems when the PCM is completely stock. Chips/Programmers will sometimes mask problems/fool the PCM.
If you decide to do this, it will assist us with more accurate data
Changed the cps. It's running again.
Koer test I have p0476, p0541
Cylinder contribution test I have p0275, p0281 and the p0541 again.
At idle my icp is between 565 and 590 psi, .8 to .99 volts, and 7.03% duty cycle around 1700 rpm between 1215 and 1240 psi, 1.4 volts and 15.25 duty cycle
Checked the dtc again p1316, p0541
Looking at just the ICP/IPR, this has the scent of a bad ICP sensor - but a bad connection to an injector or two can cause the same readings.
Ignore that P0541 - most AIH systems are deleted.
The P0476 is a concern, unless you have the EBPV delete. It's possible you have an exhaust leak. If the logs show a low EBP at WOT, it's time for a soot safari under the hood.
The P0275 and P0281 are strong indicators of either a bad UVCH, or a strong coincidence that two injectors next to each other are failing. UVCH is most common here, and using the 42-pin method in my UVCH link is the easiest quick-check, then work your way toward the valve covers.
Given the rough run, the ICP/IPR, and those codes - these line up with a bad UVCH or two very weak injectors in #5 and #7.
Since #7 shows up each time with a P1316, a quick easy check would be pull the UVCH harness off the passenger side and inspect both halves. A burnt or melted pin might be easy to see. If not then you're busting out the DVM, etc.
On edit: good luck on the interview!
Thanks I need all I can get on the interview
