I have a 2005 Lincoln Navigator and I am going to install rear heated seats (carbon fiber) does anyone know a good key on power source to hook it to in the kick panel fuse panel?
I would run the power to the heaters through a relay, then you should be able to connect the relay coil to about anything that is key activated. Put your on/off switch in this line and you won't need a high power switch. Don't forget to fuse the main power to the relay.
The kit came with a relay and fused for each seat built into the wiring harness...looks pretty straight forward other than finding a key on power source, I was just wondering if someone had a good fast source.
