Cold truck starts, dies immediately... then crank no start.
So the shop *THINKS* it's the engine harness. They're saying the wear and tear on it is causing the intermittent problems. They're quoting $700 for the harness and 5 hours. I'm thinking no way in hell. She's running now so I'm going to go get it and make the trip before my wife makes me rent an SUV to go see her parents.
Wish me luck!
Wish me luck!
Wish me luck!
Wish me luck!
Yeah, I've done the ICP pigtail already... it may very well be time to do the IPR over again. I just made the 11 hour trip with no problems... truck's running great. It'll be interesting to see whether it starts in the morning or not.
Guess who?!
Truck ran great for a week and fired right up this morning... made it about 50' and shut off. Now crank no start with a P2290 ICP too low engine cranking code.
Tried unplugging the ICP, no dice.
When cranking the ICP gets to about 150 and then starts falling. IPR hangs at 77.8. I guess I'm going to go try another ICP because that's about the extent of my mechanical ability... I'm not overly comfortable pulling the turbo and trying to get to the IPR to check it unless it's really easy and I just don't know it.
Guess who?!
I managed to get the degas bottle off (of course I also managed to break the $65 Y-pipe), and the FICM out (I'm never going to get those back bolts back in) but I can't for the life of me find the IPR. I see the injectors and I see a weird looking cable that appears to be wrapped in tin foil behind them, is that the dude I'm looking for?
It's under the turbo area, just above the ICP.
I'm planning on going back out now and seeing if I can find it. I'm really just looking for the pigtail condition as the IPR valve itself was changed within the last three months.
I have a late 04, so my ICP is on the passenger valve cover.
#28
Boy there really is no rhyme or reason to the engines they put in the Ex's. I have read of guys that have an 05 with early and late build, and you with an 04, late build. Did they just grab whatever they had their hands on for the Ex's on the assembly line?
The pigtail will be the only thing going back down that direction I would think unless an Ex is different? Since you don't have an ICP under the IPR...........
#29
#30
Well while I was at Ford getting my overflow pipe, I talked to one of the service managers that I've dealt with over the years. We went through all the issues I've been having and his ears perked up when I told him the other shop had theorized that it was the engine harness giving me fits. He told me it could very well be the case and he had a customer who had a very similar problem recently and they were swapping parts left and right until they found out it was an intermittent short in the wiring harness.
I'm going to put it all back together (with my new $65 hose... sigh) and see if it starts. If not, I'll wiggle the harness going into the PCM to see if it'll start.
I've been experiencing really weird issues that are VERY similar with this truck for almost six months now... it'll be interesting to see whether or not it ends up being the harness.
