Alternator issues
on
I went through 4 remans before I finally got everything fixed. I was having issues with batteries, voltage regulator plug and alternator. Replaced the alternator and that one went bad...found out the issue was with the plug, replaced that but the alternator was spent again. Replaced alternator again but still having issues. Batteries were weak now from being ran down too much and the plug also got burnt again. Alternator was not pushing out the right power still so it was alternator #4, plug #2, and replace the batteries as well. No issues since and this was last Thanksgiving.
Found the issue was the plug because I would wiggle the wires while the truck was running and you could hear the engine get stronger.
Nearly identical to brake cleaner. Personally I use brake cleaner to clean connectors then a dab of dielectric grease.
Sometimes the pins in the connectors get weak and nothing will save them but a new connector/pins.
on
Late 2013, the alternator went out on my newly acquired 6.0. From January 2014 till June 2014, I went through 6 Autozone alternators before I finally got one that would maintain voltage. It became frustrating that it wouldn't go above 13.5 volts, but it was nice that it could maintain that cruising.
To that end, I stopped by a local, well known Alternator and Starter rebuilder and had them look at it. They pulled it apart, inspected it, and found that the regulator was below spec. The replaced the regulator and for a year and a half it delivered the 14-14.5 volts cruising. It finally failed last month, so I bought myself a Leece-Neville 230 amp alternator that has proven to blow the rest out of the water with it's superior charging ability.
Well, gonna love this. Took Big X for a drive, gt everything up to temp. 15 minutes into drive, lost all electrical power again. Thought plug was loose. Pulled it off and put it back on. No help. Took it back to O'Reilly's and had it tested, it failed. Got a replacement and had it tested before leaving. Now we wait and see how long before this one fails. Seriously wondering about quality of re-manufactured items. How warm should a running alternator get?
It truly is...
