POST PICS OF YOUR EX IN THE SNOW!!!
#181
#182
OK all, sorry that I have been gone from the forum for a couple of weeks. My 6yo step-daughter was in Texas when Goliath hit and her birth dad couldn't get her home. He gave up at Lubbock.
So.... since we had to go rescue the lil one, we loaded up the Ex with snow blower, shovels, -20 degree bags, food, water, changes of clothes, and a few other things.
Made it to Lubbock no problem and spent the next 2 days plowing people out.
Well I have been trying for 20 minutes to post pics, but it is not working. Will get em in when I can, I guess.
EDIT: Still cant post pics....
#183
Thank you, I bought that from a friend early last spring. It's kinda beat up a little on the outside so I actually like it more in the way of someone is less likely to think I have good stuff in it.
It is loaded on the inside with E trac, fold down bed, cabinets, compressor, winch, batteries, 110 lighting and an RV propane furnace.
I'm not an expert in the effects of aerodynamics, but a long V nose can introduce a strange dynamic different than what one might expect. The expectation might be more "slipperiness", less "frontal area" exposure, and decreased drag with a long V nose. But strangely, the wind pushes against the broad area of the long nose sort of sideways, at the front of the trailer which is least stabilized by gravity on the trailer's axles.
Anyway, a shorter V nose accomplishes a lower drag coefficient on the frontal area, without introducing this other effect. That was the first thing I noticed about your trailer. The second thing was the fact that the trailer's tongue could accommodate any type of weight distribution system. The third thing I noticed was the slightly sloping front fiberglass cap, which not only slopes slightly for improved aerodynamics, but also sheds water forward away from the man door on the side, and I'll bet is even translucent to let light through.
Sorry for the off topic distraction... but many snowmobile trailers do have V fronts with drive through doors, so tangentially speaking, this is still sort of distantly related to snow. Kind of.
#184
It doesn't look beat up to me. It looks good. And I noticed the furnace right away. What I especially liked about your trailer was that it was a V nose, but a short V nose rather than a long one. Sometimes, the greater sail panel area of long V nose trailers end up being too large of a surface area... that the air pressure from passing semi's pushes against, inducing a yaw movement at the hitch.
I've never towed a traditional 5' V nose style trailer, but I understand what you are saying. This one does tow well with a the extra tongue weight of the V and what I have up front.
That front cap is not light emitting in the way that the front roof area has a panel "header" there. Drops from the ceiling about 7" and spans the width. A cd player is now in it.
It's a very used setup. I did tow it on Saturday and I think I will need to put new backing plates on it, or st a very minimum adjust the brakes. I'm not getting much help from them. But that's easy for me to deal with.
I would NOT be thrilled to tow in the snowy conditions with the hills / mountains we have here!
#186
#191
#194
