Thanks, have checked owners manual and it has listed 2 fuses. Fuse #10 listed as 40A trailer tow and fuse #90 trailer tow battery charge. Don't know which is power pin on 7 pin.
Whether you have enough power really depends on the amp draw of the compressor. Most 12-volt compressors will put out enough pressure, but at a limited volume so make sure that your compressor will put of the cfm you need.
