Batteries
Batteries
I know this subject has been done, my question is has anyone had any experience with Sam's club Energizer AGM batteries. It seems like a good deal. My Motercraft batteries are pushing 5 years of good service and I have noticed that it isn't turning over as quick as she used to. Thanks all! I talked the wife into getting new batteries by saying FICM...I told her a FICM costs nearly 3 times as much as two new batteries!!
Guys
If there is one area I wouldn't skimp it's your batteries. A cheap set of batteries can cost you a FICM. I had motor craft before and had some weird **** happen like the cases splitting off the negative post. I switched to the Sears DieHard Platinums which is made by Enersys. Actually I bought them from Enersys instead of paying an inflated price from Sears. My trucks in the shop but needless to say they rock. Very happy with them and worth the money.
Up here in Canada we have rebranded Northstar Made in USA AGM dry maintnenace free batteries at $169 a battery. This is a really good battery in a group 65 for our trucks and if you can find them I would buy these over these others being mentioned. They come with a 5 year 100% free replacement and next three years free jump starts. I am running Motorcraft group 65s at 850 CCA but this is a wet lead acid and they need constant water addition and our bumping roads they often spill a bit of acid, meaning they don't do as well as a solid maintnenace free. I am thinking next batteries will be These for me, unless I end up buying a new truck.
69cj I completely agree and I am not saying don't shop around all I am saying is you get what you pay for and sometimes cheaper is not better but that doesn't mean get raped either.
Jmoen7 thanks for tripping my trigger! The Sears Die Hard Platinum in our or size is the Enersys Oddessy which is in my truck. I love them so far and my truck turns over with authority 3 years in.
Odyssey are more than double the price of my above example. We use them in all UPS applications small and large for computer and other specialty equipment. Even after 10 years, they often have some life left in them for power storage applications off grid.
You get what you pay for, I would compare cold cranking amps, normal temp cranking amps, reserve amps, and warrenty. I would stick to a group 65 for fitment issues. When replacing, be sure all positive and negative cables are clean and double check all ground points.
Odyssey has a sale right now, making their group 65 batteries cheaper than the comparable sears die hard platinums by 30$. I'd get a set myself but i just picked up the biggest i could get at crappy tire here in canada last winter, already running into lower voltage than my mind can handle at 10.2v while cranking so they'll get the trickle charger all winter. maybe ill pick up some odysseys on black friday from the americas
Group 65 from Canadian Tire Northstar made, are Ultra AGM and are $169.99 Canadian. They have a higher model which is over $230 which is a AGM XD. 1150 CCA, 120 amp reserve, in the ultra. 1350 in the XD, bout same reserve. I just bought my wife a new ultra, on sale $139.99 for a group 24. They are on sale.
