1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
California Smog Not Ready
Old 11-24-2015, 10:52 AM
quietman's Avatar
quietman
quietman is offline
I have a 2005 6.0 (Excursion) that is showing the "misfire monitor" as not ready. This is a continuous monitor according to the smog tech, and it is
odd (to him at least) that this monitor will not report as ready.
After being told "just drive it more" and having no luck with that, I took my truck to my Diesel mechanic who double checked that there were no codes and then re-flashed the computer to the latest OEM tune- which I already had.
Still have exact same problem.
The truck is stock.
Two months and a thousand miles of driving and even trying to follow one of those "profiles" has not changed a thing.
Thanks!
Old 11-24-2015, 11:27 PM
scld1354's Avatar
scld1354
scld1354 is offline
Not sure what you mean by "profiles".
When your mechanic re-flashed your ECU it reset the "not ready" codes. I removed a tune from my 7.3 the day I took it in for smog and it hadn't been driven enough. The smog tech told me the ECU wasn't ready yet. So, depending on when your mechanic re-flashed your ECU, you may have done the opposite of what you wanted to do.
THIS is the link for putting the 6.0 through it's drive cycle and getting rid of the "not ready" codes (down the left hand side, 7 lines from the bottom, titled "On-Board Diagnostic (OBD) Drive Cycle"). Good luck!!!
Bonanza35
178
09-29-2018 07:05 AM
quietman
03-16-2016 02:35 PM
SARDiverDan
17
01-30-2016 11:06 PM
quietman
11-25-2015 09:07 PM
stangclassic66
16
10-25-2010 10:26 AM
Quick Reply: California Smog Not Ready
