Backup camera
Backup camera
Does anyone have an aftermarket backup camera installed that has the image viewable through an aftermarket radio? I asked SANTA for a radio and backup camera for Xmas, but do NOT want another monitor on my dash nor a crappy image through a replacement rear view mirror.
I have an '04 so it does not have all the fancies!
I'm sure a ton of people do. I think most aftermarket double din decks are wired for a backup camera nowadays.
I've been researching this for quite awhile and am about to pull the pin on an android offshore double din head unit. The 'carjoying' one is the brand I'm looking at. Affordable and lots of functionality.
I bought a used pioneer that was out of another 2005 f350 so it plugged right into mine. I bought a backup cameria from Amazon for under $20. It works fine but I had to run an rca cable to the radio ftom the tailgate
The cable that came with the camera was too short so I had add about 6 foot to it.
I've got a Pioneer AVH4000-NEX radio with the Pioneer ND-BC6 backup camera hooked up to it.
Good things (just related to the backup camera):
-turns on automatically when I go into reverse
-nice wide angle lens
-good image both during the day and night. At night in particular, it shows what's behind me more clearly than the mirrors or even looking out an open window
Bad things:
-something causes the image to momentarily reset after 2 seconds [so you shift into reverse, 2 seconds later the image will go blank, then return, after that it's fine indefinitely]. Of course, it always happens just as I am trying to get the distance right to hook up a trailer.
Bad things:
Carjoying system. Works well, $300 for everything but you have to be a tad bit experienced in wiring your truck. Pre-wired for a backup camera. They included one in mine but I opted for a licence plate frame version. Has great sound, GPS, full Google maps (leeches off your data but it's minimal) Um... A couple bugs here and there but nothing major. Install will take you about 3 hours start to finish. Took me much longer because I had to keep buying tools and they didn't have the harness I needed for my truck so I had to build one. Soldered it.
Installation is a breeze. You could seriously do it with minimal youtube-ing.
It's the software that has the issues.
The two I've noticed:
Volume **** won't work in certain rare instance when Google maps is navigating. When it's just open, it won't have an issue, but when the lady dims down the music to talk, she has an issue.
The microphone setup is pretty lousy. It's plug and play, yes, but the actual control board and stuff for the mic and input audio is lacking. Have to yell for people to hear me. They say a firmware update in the future will fix this.
In my particular situation the included front view dvr usb camera doesn't focus right. Still working on that. A replacement camera does work (sort of... Need one with manual focus) so just chock this one up to cheap Chinese $2 junk for the camera.
A couple smaller, probably not noticeable quirks here and there that almost never show up, but that's about it.
If they quote you anything over $500, I'd say tackle the job yourself. You'll never learn how to do it if you don't try.
Noober0x do you run the torque app at all? Thanks for the response to my inquiries.
Madsonp, if you never try anything else how will you know one is superior than the other? I've had many different stereo setups over the years, always a major brand like pioneer, ken wood, or alpine. I can't get past the pricing and functionality difference though between the big players and these new android devices. I'm going to try one I think and put it in my '03 before deciding what to do in the '11.
Diamnd1. Best of luck with what you decide but remember installing a stereo is quite easy but if you aren't familiar with it it can be easy to waste a lot of time and have a sub-par install that won't last or even worse cause electrical gremlins. Like all things automotive there are good and poor 'pro' installers out there. Ask lots of questions about what/how they're going to do it so there are no surprises.
this exactly. had a Koolertron camera from Amazon that pleasantly surprised me on how well it worked, hooked up to a Pioneer AVH-P1400DVD in my F-350. had less than $280 into the whole setup new.
