Weird cooling issue
Weird cooling issue
96 F150, 302 4x4 E4od truck. Truck was running hot and temp was rising and falling for a wile. when it stopped falling I replaced the thermostat with a 180 degree stant brand. fixed the hot running but it wouldn't heat up into normal range so I replaced it with a 195 degree stant brand. It still won't heat into normal range. I also replaced the water neck and this one has a rubber gasket rather than the Film type that was original.
So what I think may be happening:
1. There is something I simply dont understand about the engine cooling system
2. Both 180 and 195 degree thermostats are too cool for a 302.
3. the rubber gasket on the New after market water neck is not compressing fully and coolant is constantly flowing around the metal ring housing of the thermostat.
BTW, when I pulled the 180 degree thermostat out it was not stuck open.
Anyone got any ideas?
Thanks in advance for your input!
Best,
Phil
Best,
Phil
