Wet sanding 70 f100 original paint
I have a 1970 f100. The paint is original and is very dull and faded. Looking to wet sand it to bring back the shine. Looking for suggestions. I did a portion on the truck using 400 grit to 600 grit to 1500 grit then rubbed a compound in with a clean towel by hand. came out okay. looking to see whats the best method.
The first picture is before i started i took some soap and water and cleaned the upper portion of the bed. the part near the cab is the driest part thats what the whole bed looks like when dry. Second picture i was just doing different sections. The third is the close up of the paint dry after wet sanding. Then the last pictures is after compounding majority then wiping off with clean towel. the last picture is of the truck a year ago
400 grit is going to take a lot of paint off really fast. You are also putting really deep scratches in the paint surface that is going to take a ton of work to get back out.
Have you thought of just hitting the stock paint with a good compound polish and wax? I have had extremely good results doing this, especially on old single stage paint.
The thing you need to be extra careful of with old paint is there is not a ton of it in spots on the truck and you can go through it really fast with wetsanding.
In your photos I can see a ton of scratches from the wet sanding you did. Not knocking you, just letting you know what I am seeing.
Sean
Sean
Heck yeah.... Using a rotary buffer is the only way to make the scratches finer and finer... wetsanding only goes so far. Basically, the scratches need to be so fine that that they are filled by wax or that they are eliminated completely. That is what "cutting and buffing" is all about.
Skip the sanding, you are removing paint and not just oxidation. I would use a wool pad ,but if you don't have experience I would suggest foam. Use a random orbital sander like the porter cable or flex. Use a cutting agent like megs diamond cut and a heavy cut pad. Move up towards polish. Fyi your wet sand techniques are adding more scratches. I suggest using either products from adams polish or the chemical guys.
I did this to my truck recently with pretty good results.
Here is what I learned:
1) Do the least you can to get good results. If it just needs a little polishing compound to bring the shine back there's no need to remove paint with wet sanding.
2) Start with no rougher than 600 grit, anything coarser will take too much paint away. Work your way to 2000 grit then polish. I used Turtle Wax heavy duty rubbing compound then TW light polishing compound.
3) not all areas of the truck need the same treatment. My hood needed 600 to 2000 grit wet sand and polish while the doors and bed needed only 2000 grit wet sand and polish.
4) Buy the appropriate sandpaper and plenty of it. Tear it down to appropriate sizes when needed. Keep a spray bottle handy to re-wet your work area as needed.
4) Sand up to ridges and high spots first and hit the ridges and high spots last and lightly as these will tend to wear through to primer fast. Ask me how I know that.
5) A buffing machine, even a rather cheap one, will save you some sore muscles.
Hope this helps. Post pics of your progress.
3M Perfect-it is pricey but it does a great job of removing oxidation and scratches finer than P1200. Use a soft cloth or buffer, the finish you get is amazing.
on
I'd think I would have first tried using Clay Bar by Mothers, Dang never want to sand old paint to bring back a shine, It just needs a good cleaning by removing the oxidation. As oxidation is the only thing that has turn the paint dull. Just HD rubbing compound would have broth back the shine then hit it polish & buff it out good put a coat od wax on it.
Orich .
Orich .
