Need a distribution box diagram legend
My son just purchased a '94 F150XL with about 200K on it and it sounds like it has a cylinder(s) not firing and it's getting crappy gas mileage. We have replaced the cap, rotor, plugs, and wires but still have the same problem (found a ground strap loose from the engine to firewall and connected, too). I was going to see if any codes are stored, but my scan tool will not come on by itself when connected and the key switch is turned to the "on" position. Instructions said to check fuses to the EEC connector. We opened up the distribution box cover but the only thing stamped on it are the fuse and relay position numbers. Some fuses are missing and I really wish I knew what those slots go to. Would sure appreciate a link to some kind of legend. Thanks.
You might have a bad PCM Computer. You can open it up and check the caps for leakage or just replaces the caps. Replacement PCM Computers do not always work the best.
The PCM Computer is the number one reason for the code reader or scan tool not reading codes.
I dough that you have a scan tool as they are very high dollar items but the in result is the same if you have one.
It is located as in the photos below.
You take it out between the inter fender and the fender after removing the front drivers tire. The center bolt in the plug is a 10mm socket size. You will also need to stick a broom handle between the fenders and there is also small nuts above and below the plug.
arkiados
11-29-2022 08:31 AM
cmoses
02-23-2016 07:36 PM
