6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Mixing Green Coolant with Gold Coolant - **Coolant FLush Results**
Old 11-05-2015, 01:19 PM
parcours's Avatar
parcours
parcours is offline
My Ford dealer accidentally mixed green coolant into my '08 F250.
Ford replaced the degas reservoir and the tech "mistakenly" added green coolant to the system.
I happen to catch it before they started the truck. I told them they needed to flush the system following the Ford published coolant flush procedure. They indicated they would, however the procedure they use calls out for evacuating the system through the degas bottle via vacuum and not draining the system through the engine block drains and radiator.
Have you guy heard of being able to draining the system through the degas bottle? I don't think it can be done...
I fill the system through the degas bottle using an Airlift vacuum system.
Also, the dealer says Green coolant mixed with Gold will not harm the system. Mixing Orange with Gold is the problem. I completely disagree given Ford's own criteria for the use of Gold vs Green coolant.
What do you think.
Old 11-05-2015, 06:32 PM
slowmans's Avatar
slowmans
slowmans is offline
Id call ford customer service....
Old 11-05-2015, 09:45 PM
parcours's Avatar
parcours
parcours is offline
Well... Seems that Ford has changed the color of their Gold coolant to have a green hue...
They opened a bottle of Gold coolant and it's actually a light green.
When did Ford change the color of Gold?
Old 11-07-2015, 10:15 AM
parcours's Avatar
parcours
parcours is offline
Here the gold coolant ford put in...
Gold coolant<br/>
Old 11-07-2015, 12:55 PM
RM2738's Avatar
RM2738
RM2738 is offline
Gold coolant<br/>
Doesn't look like Ford Gold I've ever used.
I can see how they may believe getting most of the green out if they only filled the degas and never started the engine. It never circulated through the system. I still don't like the situation. No telling how green and gold will mix in the long run. When you start mixing stuff, nothing good can happen. It's like putting an ounce of lemon juice in a gallon of milk and mixing it around. That one ounce will ruin the whole gallon.
Old 11-07-2015, 04:02 PM
slowmans's Avatar
slowmans
slowmans is offline
They for sure put GREEN antifreeze in, I would demand a flush!!
Old 11-07-2015, 06:19 PM
parcours's Avatar
parcours
parcours is offline
I agree. It's green. But when I opened a sealed bottle of Gold coolant, it was green....
Ford must have changed the formulation. If I didn't see it with my own eyes I wouldn't have believed it.
Old 11-07-2015, 06:20 PM
senix's Avatar
senix
senix is offline
Received 1,417 Likes on 1,012 Posts
I think you got taken to the cleaners. You need to not drive the truck and take it another location where they will put in the ford spec coolant per your owners guide.
You don't vacumn it from the degas bottle.
You open up the petcock on the radiator, pull the block plugs.
Old 11-07-2015, 07:28 PM
parcours's Avatar
parcours
parcours is offline
Senix, I agree and pushed back really hard on the dealer. Then the service manager got a sealed "Gold" coolant bottle from parts. I opened it and poured out some coolant into a clear cup... It was that green color.
The new coolant is in a red 1 gallon bottle. I have a couple of gallons left over from last flush I did and it's in a white 1 gallon bottle and it's clear/yellowish in color.
The dealer showed me a 2015 F250 6.7 and it's has the same greenish color in the degas bottle.
So I don't know what to think.
Old 11-07-2015, 07:43 PM
senix's Avatar
senix
senix is offline
I think you need to check the specs on the bottle against the owners manual.
The 6.7 uses a orange coolant. Not green. and not the gold either.
I guess as long as the bottle has the correct spec on it then it must be as you said. A change.
Old 11-07-2015, 09:17 PM
parcours's Avatar
parcours
parcours is offline
What color is this to you:
Old 11-08-2015, 06:03 PM
slowmans's Avatar
slowmans
slowmans is offline
That is gold, what is in your degas is green, I'm telling you you are wrong and the dealer is wrong, scroll up and look at the difference. Hey its your truck, your dime but I am telling you they messed up!
Old 11-08-2015, 08:40 PM
parcours's Avatar
parcours
parcours is offline
LOL...
I pulled that sample from the degas bottle....
I'm telling you guys, Ford changed the formulation and made it look greenish...
Trust me, I have always done the right thing when it comes to maintenance with my 6.4. I got on the dealer really hard when I saw green in the degas bottle.
If I hadn't opened up a sealed (red) Ford 1 gallon bottle labeled GOLD, poured some into a clear cup, I wouldn't have believed it neither... It's green guys.
Today I changed the fuel cooler coolant. I used Ford Gold I had from my last flush (white bottle), and yes it's clearish, gold in color.
Maybe one of the tech's can chime in here.... Did Ford change the color of their Gold to Greenish (at least the way it looks in the degas bottle).
Old 11-09-2015, 05:09 AM
senix's Avatar
senix
senix is offline
interesting. I guess just be very careful when you go in for maintance that is not topped off with the universal stuff.
Save that receipt.
Old 11-09-2015, 08:10 AM
parcours's Avatar
parcours
parcours is offline
Save that receipt.
I'm going to, for piece of mind flush the system myself...
I'll purchase some new Gold and take pics.
If I remember correctly, it' took 20 gallons of distilled water to perform the flush. Along with several hours and the Airlift vacuum tool.
Sure wish I could get to the block drain above the starter without having to remove the starter. But with two-three good flushes, running the truck up to temp with distilled water I should be good.
Quick Reply: Mixing Green Coolant with Gold Coolant - **Coolant FLush Results**
