It shouldn't start with the IPR unplugged. The ICP should be unplugged when starting. I know there are lots of three letter acronyms and it is easy to mistake one for the other. The ICP is on the driver head at the front, close to the lift ring.
You can hook your gauge up by removing one of the oil galley plugs along the inside of the head.
You're right, I thought I remembered it being the IPR. Here is a video of the truck with the ICP unplugged then plugged in.
I got my IPR reseal kit today so hopefully I can get that in this weekend, and hopefully that will fix it! if not I dont know what I'll do. Also, I saw your thread. Sorry to hear about that. At least its an excuse to get a T500
i thought I would revive this thread instead of making a new one. I finally got the time to pull my IPR and reseal it, and I also pulled it apart and cleaned it just to be thorough. When I put everything back together and refilled the HPOP, the truck ran like it just came out of the factory. But once the old oil from the pan got sucked up it started running rough again. The oil only has about 2500 miles on it, so does anyone have an idea of what could be causing this? I may just get a new IPR and see where that gets me I just don't want to spend $185 dollars on something that may not fix it.
What kind of oil is it? Hard to imagine it could be so broken down in 2500 miles that it affected the injector operation, but you never know. Are you using an oil additive like Lucas? That could explain it. Hope nothing else is wrong.
Rotella 15W40, nothing special. I used a lucas oil treatment about 4 oil changes ago but havent used anything since. I usually change it every 2500-3500 or so because I drive mostly short trips.
