aftermarket water pump problem?
My CVF RACING pulley combo is specifically made "so you can retain your standard rotation pump." I RAN out to the garage and bolted the CVF RACING pulley onto my old water pump. Bolted right on no problem. Well.....one problem....my mechanic says the old water pump is reverse rotation. Went to the ford dealership. He couldn't tell me if the pump I showed him was forward or reverse or what it may have come off of. I am not able to insert photos. I have done it in the past. Anyone else having that problem?
Hey Matt,
If you think you will be on here pretty often - you might want to join.
Membership costs $20 & get's rid of most of the annoying advertising & you
get a little paper clip icon that you click & just post pics from your hard drive (very easy).
Posting some pics might make this easier.
Good luck over there in Bakersfield.
Ben in Austin
1950 F1
Ben in Austin
1950 F1
Hey Matt,
Ben in Austin
1950 F1
Ben in Austin
1950 F1
Well it is confirmed that I can use my new aftermarket clockwise rotation water pump with my current timing chain cover. HOWEVER.....My old water pump had three holes around each water port and my new pump only has two per each port. I would really feel more comfortable if I could find one with three holes per port. WHAT I NEED is a water pump with the lower radiator connection on the driver side and three holes per port. Maybe a heavy duty application as stated earlier. Anyone have any idea how to track that UNICORN down?
z1121jack
11-21-2010 10:49 PM
jeremychance
18
10-13-2010 07:11 AM
redlead3
05-10-2002 09:45 AM
