LETS SEE YOUR 67 TO 72 PICK UP
#166
on
Originally Posted by 70FE250
Thanks! Mirrors stickers were definitely not my idea they were from previous owner. Only mods I've done is stuck a hose in the bed rail holes and saw mud continually come out for 5 minutes straight and washed out as much mud in the back too, but with the higher lift in the back since a 250 it all went to the front
#167
The following users liked this post:
#169
#170
#171
This is my 72 Ford Explorer Edition my wife calls it Miss Lemon Peel as that is the paint color from the newer Camaros.
I bought it as a parts truck but it was too nice to junk it. It only had 79000 miles on it. So now I am doing a body off restoration. But its not going back as it was. So far I have added a disk brake set up out of a 78 f100 which also supplied the power a 400 with a C6.
Thanks Pat. :-)
Thanks Pat. :-)
#174
#175
They had the standard three prong male pigtail like the factory bulbs. They sure make night driving more pleasant. I put them in when I did the engine swap and 3G alternator so I didn't have the old charging system to test the dim at idle thing. I have one on my 76 KZ750 and it's just as bright with the engine off or at idle as it is at high rpm. The LEDs pull less amps so relays aren't a requirement. Thanks for the compliment.
#177
