No, it is a Transfer Flow tank especially made to replace the original gas tank, 47 gallons. If Titan had made a replacement I would have bought it since the Titan is a nylon tank and lighter. The TF is steel and heavier, but that's the only replacement tank available. You can always get an "in-the-bed" tank, but I didn't want one of those. My truck weight went to 8560 which is 460 lbs more than it was before I installed the tank.
When did you buy your tf tank? I talked to them last month and they said they weren't making them anymore due to new emissions. I may have waited too long.
I had it installed 2 years ago. If nothing else, you could add the bed tank. Not as nice as the replacement tank but will give you more fuel.
I'll do a excursion tank mod if I can't get a oversized replacement. I keep too much stuff in the bed of my truck plus I would like to be able to use a camper if I find a nicely priced one. thanks
