What remote start fob should be bought?
11 Expedition Limited with sync and mykeys. I have a 2 way ford gen2 remote start module under driver'side. I think I need part # 9G1Z-15K601A remote start fob, which has been updated to DL3Z-15K601A or is there another remote I should be looking at? Thanks for your responses!
I skipped the ford system, I tried it on mine for a while and ended up ditching it. Even the factory remote sucked distance wise and feature wise. I went with a Viper 5906V (I think, it's the color remote and 1 mile range). The features are significantly better when you compare to Fords lack luster system. I've got it set to start when the temps drop below a preset level, rise above a preset level and it will even start the truck and exercise the battery if the voltage drops too low to prevent dead batteries.
Distance on the Viper is pretty far and you get a positive feedback if there is a locking or starting issue, ford you don't.
Remmons
11-04-2015 06:47 PM
ddlv
01-20-2009 08:48 PM
