Best way to give an F150 dualies?
Hello, Ford-Trucks! I will be making an extreme custom vehicle out of an '86 F150. I figured if I could find help anywhere it would be here. Part of the build is adding on dual rear wheels. Can someone tell me the best way to go about doing this? I have heard I could swap out the axle for a F250 dualie axle, or get adapters for the wheels. I'd like to get the adapters (less work, save me the trouble of finding and transporting a whole axle), but I can't seem to find them anywhere. Any help?
F-350 pickups have wider spacing between the spring perches than F-350 cab-and-chassis. I'm not sure which is closer to your F-150 frame, but I'd guess the pickup. Still, with the amount of fabricating you'll need to do for this entire project, moving spring perches is nothing. For that matter, with all the steel you're going to need to find and transport, getting a duallie axle isn't a big deal either.
Of course this would mean your front and rear wheels would have different lug patterns. But that probably wouldn't be a big concern for a project like this.
My comment was a euphemism saying: What would you DO with such a thing? What sort of utility and usefulness does it have? Does it haul a camper or construction materials from Home Depot or landscaping rock? Probably not. Can it be used for rock crawling and camping and four wheeling? Probably not. Can it be licensed and driven on the street and act as a DD in the snow? Probably not. The actual, physical MPH is irrelevant anyplace except maybe the salt flats of Utah.
I used to sit around campfires late at night with other Scout leaders. That gave a lot of time to talk about a lot of things. One of the things we realized is that we all spend time, effort and money on stupid things. I was building a '71 Bronco, which one other leader in particular thought was ridiculous. On the other hand, he had a ham radio setup that cost close to what my Bronco cost, and had a laser pointer that he paid over $100 for. So we decided that as long as we were happy with the stupid things we were spending money on it was all good.
Do I think it's a good use of time and money to build a replica of a movie prop? Absolutely not, so I won't do it. But if the OP wants to, so what? I can still try to answer his questions.
Looks to me like the movie vehicle has a fake second engine up back. The original is still up forward.
Also appears to be made from a 1 ton truck, you can see the massive rear leafs in the first picture in the thread.
I would find a 1 ton truck with a decent frame and work with that, but I second the above suggestion of buying a 1 ton dually axle for the rear.
You can see the solid front axle... and that didn't come in any half tons.
But the OP has already rejected the idea of getting the right vehicle and doing away with all this bs.
I guess he's only interested in some buring man 'art car' and not the safety of any innocent bystanders.
If it were otr in my juristiction it would be towed on sight and likely crushed, because it wouldn't be leaving the impound until it was properly inspected and registered.
#28
Humvee Driver'
Check out Welcome - Arrowcraft :: Helping You Handle the Road for over 30 years!. Hope that helps or gives you another option.
#29
#30
