Crank pulley belt one rib off
My burb started doing that after I changed out the water pump. Of course I had to reuse the smooth pulley from the old water pump but the shaft on the new pump must have been a tad shorter and the smooth pulley had a slight groove worn into it. The problem went away when I ground the lip off the edges of the groove to make the pulley smooth again. I did it on a lathe with a file but I imagine a sanding disk on a grinder and a little care would be good enough.
Received 4,135 Likes
on
I ran into a similar problem when I installed the V/A frontrunner system on my 351W. The aftermarket harmonic balancer did not stick out as far as the OEM version so I had to buy a spacer to correct the alignment. Much to my surprise I found a vendor online who sold such a spacer...turned from billet and included the proper mounting bolts. $23 later I was on my way. You can see the spacer in the photo, it sits right behind the crank pulley.
The power steering pump pulley was also a little tricky to get in alignment...no adjustment other than how far you press the pulley down on the pump.
Spktyr
24
06-09-2019 07:32 PM
73FOMO
03-19-2014 06:08 PM
thejermsr
03-19-2014 03:37 PM
