05 xlt swap 6.0 4x4 auto
Big question I'm a little stumped
Have a 05 6.0 super cab long bed xl automatic truck 4x4
Had a 06 6.0 automatic super cab long bed 4x4 xlt truck that was my parts truck. Bought complete.
So I decided to xlt swap the xl since it's the one I'm building
For those who don't know for the most part the xlt harness is mainly its own harness. Has a General Electric module on firewall. Gem. Then has two plugs that go in fuse box. And its associated fuses and relays. I used the complete xlt harness and fuse box from 06 along with its power doors
Fuses and relays are good.
I have it together and have power windows and everything else EXCEPT the locks. I have power to my switches but for the life of me can't figure it out.
The locks worked before I took first truck apart
Battery voltage at my switch but nothing at the lock actuators when I press lock or unlock button.
Any tips? I know I have my grounds hooked up.
Thanks
Thanks
I did this swap a few years ago on a 06. Did you remember to hook up the Orange ground wire that's by the door jam and fuse box? That kicked my butt because it was the first time I had seen a ground wire in a ford that was'nt black.
just checking.
Did you use the RKE module/GEM from the donor and install it behind the radio? Did you use the fuse box from the donor truck as well? and what about the instrument cluster? My door ajar switches and dome lights wouldn't work right until I had original cluster reprogrammed to tell the truck its an XLT now.
just a few thoughts...
just checking.
Bump
Used rke fuse box doors and full harness from donor
No cluster, didn't know that could effect it
I still don't have locks have batt voltage to. Y drivers side switch. And then weirdly a batt voltage that's constant to the actuator but doesn't change when switch is pressed
Really starting to get frustrating. Truck has windows that work flawlessly. All grounds have been checked along with fuses and connectors.
Really getting stumped
Also don't have third brake light when grounds are good and bulbs
Or dome light triggered by door opening and the xlt radio doesn't shut off by door open either
I had a really smart tech at the ford dealer program mine with the as-built data for a cluster from a truck that was an xlt. I dont know if these speedo repair shops can do that or not. Maybe all they can do it change the miles. If they cant then you'll need to buy a used cluster from a xlt and put your miles in it. I'll look at my extra clusters and see what the part number is on the xlt one.
Talking about the as built as data
Yeah I'd appreciate that
We can custom program it for your truck and take care of everything. We can also set the mileage and engine hours where they should be. We even have clusters in stock for all of the 05-07 models. Just give us a call at 800-547-2049, and we will get you squared away.
__________________
We specialize in repairing and rebuilding circuitry in automotive modules. By repairing these components, CBM offers customers an alternative to high cost replacement parts and a timely solution for malfunctioning vehicles.
Visit us at www.CircuitBoardMedics.com or call us at 800-547-2049.
well seems im screwed
had it at ford and talked to a knowledgeable tech and we programmed the cluster from the 05 with the 06 as built as data with no luck
still cant get the gem or vsm to communicate
no locks door switches
very confused as why we cant get it to function
everything worked in the 06
