2014 f350 1 gear chatter
Just purchased a 2014 f350 dsl with 83,000 miles. Had a wheel balance issue when I got it, since fixed. Hooked my 5th wheel up and noticed a chatter/vibration in 1st gear (automatic trans). Took it to the dealer, they reset the computer and I'm to drive it 100 mile and see if it goes away. They dropped the pan and there was a little debris, but the fluid wasn't burnt. Any one have an idea whats going on?
Crystal
Ford didnt forget to grease the slip joint their drive shaft subcontractor simply didn't put enough XG-8 Teflon grease in there to start with, for many years. Find it hard to believe this STILL is a problem. Describe the symptoms differently. Chatter to a mechanic is different than a bump slide which more describes the dry slip joint. The dry slip joint produces more of a single kathunk upon take off from a stop. Liken it to bad spring pins where the springs shift as the suspension is loaded. Chatter I would compare to a standard shifted vehicle which has a bad clutch or flywheel where you get many cycles of chatter from a take off. Or when you come in from the cold and your teeth chatter. But the OP is in the right mileage range for the dry slip joint to rear its ugly head 35-75K.
Chatter/vibration
I was thinking the same thing as spud. When you put a load on the rear axle the driveline angles change as the suspension compresses. When you apply power the twisting force of the wheels torques the axle rearward which exacerbates the issue.
Your truck puts the most torque to the axle in first gear, so it's entirely possible that it takes full power in first gear to move the pinion angle enough to cause a vibration. Fairly confident the issue isn't the transmission.
Only really noticeable when towing
Have your dealer check into driveline angles. I've attached a TSB from a few years ago. Doesn't apply to your year but the principles are the same.
Yes, as well as a Ujoint as W mac said. Ive seen Ujoints do funny stuff. So does your truck have a carrier bearing between the two drive shaft halves? If so check it and the driveline angle as mentioned by spud & Tom. The carrier can be shimmed if it needs to go in that direction. Google drive line angles and check yours with it loaded down. Only takes a couple of degrees to make a ujoint unhappy.
Mine was vibrating a bit on my half ton last year after i changed leaf springs. I ended up changing the u joints in the rear driveline and balancing the driveshaft. Noise was gone along with other ones I didn't even know were there. I would vote for the change in driveline angle causing the problems as I know it did in my half ton. As well I might note that I could only notice the vibration in 1st gear as well.
