Crew Cab Door Stuck Closed
Old 10-17-2015, 02:34 PM
hateme's Avatar
hateme
hateme is offline
i have a 84 f350 CC i recently bought, The rear drivers side door will not open.
I took off the inside panel, the rod that goes to the outside handle is broken.
The inside handle moves all the rods but does not unlatch it.
Im pretty sure the latch is rusted and seized.
Is there anyway to remove the latch without opening the door?
102
Old 10-17-2015, 02:51 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
NO, 10 characters
Old 10-17-2015, 03:11 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by hateme
i have a 84 f350 CC i recently bought, the rear drivers side door will not open.
I took off the inside panel, the 26596 rod that goes to the outside handle is broken. The inside handle moves all the rods but does not unlatch it.
Im pretty sure the latch is rusted and seized. Is there anyway to remove the latch without opening the door?
The latch (26412) is located on the C pillar, the door has to be opened to remove it.
Has the 26596 rod broken or has its 29152 nylon clip broken?
Old 10-17-2015, 06:04 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,680 Likes on 1,357 Posts
Drown it in wd40.
dannyw19
01-17-2019 09:43 AM
FloridaFordGirl
1999 to 2016 Super Duty
04-28-2011 06:52 PM
67oneowner
Paint & Bodywork
08-11-2009 06:18 PM
aerostarinNorway
Aerostar
06-25-2004 12:16 PM
94aerostar
Aerostar
01-11-2004 09:02 PM
Quick Reply: Crew Cab Door Stuck Closed
