Truck Died! Going down the road?
NOPE! Does it still. I drive it 5 miles, then it coughs and sputters and misses, and dies. Let it set for 10 minutes, fires right up, and repeat. Fuel bowl is about 1/4 full with the filter out. Is that enough fuel in the bowl? Just trying to figure out, if its behind the filter, or in front of the filter is the problem? Or, electrical? I just don't see an electrical issue, making like its running out of gas? But, I'm no expert, that's why I'm asking you experts! LOL
I was thinking something plugging the fuel line too.. But, it would have to be something big, the pick up foot is probably about 3" diameter if I remember right. I installed new ones in both tanks, a few months back. It just started doing this about 2 weeks ago.
In your first post, which I missed, you stated you replaced the fuel selector valve off of your 89 Diesel, then this happened. Are you sure the selector valve is functioning properly? Is it an identical part?
Check your fuel pressure cranking and at idle, if you can get it started. At least eliminate that.
#28
If the truck was running good before replacing the selector valve, I would suspect that. 1 thing I have found out the hard way is trying to troubleshoot these trucks without a tool is next to impossible. I recommend you get a scanguage or AE to properly diagnose the different parts of the system. I hope this helps.
pwjackson42
06-07-2016 06:23 AM
BigBlueChevy
10-23-2011 12:21 PM
dew487
02-22-2006 06:17 AM
