Thoughts on replacing my 99 psd with an OBS?
I've read the differences between the two but I'm curious about real world reports. I have a late 99 that I will be replacing simply because the rust is getting to me and will only get worse.
This is my work truck and drives about 20K miles a year with roughly
700 pounds in the bed.
From what I've read, the OBS has disc brakes on just the front. Is there a relatively simple brake upgrade that will get me better braking or will I not even notice a difference from 99?
Also read that the transmission has not the best shift points or something along those lines? Again, is this a pretty simple upgrade if it's even a real thing?
What are your thoughts on the possible downgrade for a truck that I need to run well all the time? Should I just buy another 99+?
Only reason for the OBS is I love the styling and it doesnt hurt that I can get a nice one for 9-10K all day I believe.
Thanks, Mike
Thanks, Mike
Only way to upgrade to rear discs is to swap in SuperDuty axles. Discs do brake better, but with just a loaded bed, you'll never notice the difference.
Best upgrade wrt. shift points is to select your own shift points -- with a shfiter coming up out of the floor....
(Most of us consider an SD a "downgrade".... ).
Thanks, Mike
Thanks, Mike
TJ has done the conversion :
https://www.ford-trucks.com/forums/6...-are-here.html
I cant believe the obs has a worse turning radius then the SD. I thought the sd radius sucked. OI!
So basically you're all saying that I won't be losing reliability by switching to an OBS? That's my main concern.
Besides. I will have a second truck that will still be capable of towing and doing back up duty should my daily rig get hurt.
Originally, that's why I started shopping for an OBS.
No direct experience with an SD myself, but from what I read, you're probably looking at a MORE reliable truck with the OBS. Simpler electronics, fewer emission controls, etc. I read now and then about windshield leaks taking out the GEM module on an SD, which wreaks havoc with all sorts of on-board electrical items. We don't even have one.
TearDaClubUp
09-10-2004 04:48 PM
PWRSTRKRED
22
02-10-2004 06:55 PM
BmrHauler
12-17-2001 12:04 PM
