ford tempo excessive oil consumption 2.3
Old 12-07-2002, 12:22 AM
pancake's Avatar
pancake
pancake is offline
well it is pretty well covered in the topic....
92 tempo miles unkown but is an efi 2.3 and goes through oil like water but no visible massive leaks i get the feeling it is rings and it is passing the piston and burning it off bc it has a smell to the exaust but it is not what i call an oil smell it seems more like it is running rich....
any common problems with these engines
Old 12-07-2002, 01:34 PM
mike_long's Avatar
mike_long
mike_long is offline
Old 10-09-2003, 06:52 PM
carpe_diem's Avatar
carpe_diem
carpe_diem is offline
TTT
I think I have the same thing except mine is 87 Topaz.
106K miles.
Old 10-10-2003, 08:10 AM
tomw's Avatar
tomw
tomw is offline
rings or valve stem seals. PCV stuck or gummed up. Low viscosity oil. Leaks. Being vaporized under the piston top due to high heat.
If you don't see blue smoke, you still can be burning oil. My dad (B29 engine engineer) said that if you see blue smoke, it's REALLY burning oil.
see other post.. by carpe_diem
tom
Old 11-04-2003, 01:47 PM
carpe_diem's Avatar
carpe_diem
As I already posted ... mine is burning oil too. It appears I get less than 1,000 miles per quart, probably 800. I will try switching to 20-50.
Carbine
30
08-31-2017 06:19 PM
merlynr
Electrical Systems/Wiring
07-29-2012 08:36 AM
68Mercury250Ranger
4 Cylinder Engines
05-16-2007 11:48 PM
Ultramagdan
07-04-2004 11:46 AM
Spangler Racing
4 Cylinder Engines
02-01-2004 05:16 PM
Quick Reply: ford tempo excessive oil consumption 2.3
