New to the ford 400
New to the ford 400
I just bought a 78 bronco with a 400 and c6. The engine has been rebuilt but don't know to what specs. I do know it has a edelbrock performer 400 intake. It has a 1406 edelbrock carb. Long tube headers, a msd distributor and a 6al box. I'm guessing it has a mild cam because how it idles. I am curious if the 600 cfm edelbrock is enough carb? I checked the timing and it was at 12 degree btdc which I think I read is about right? Anything else to check?
Cato? Don't you mean East Oklahoma? I thought the town sounded familiar, so I looked it up on Google maps and it stuck the pin in Attwoods. Anyway, might you be interested in our Okie get-together next year? We have it in Skiatook.
Anyway, welcome to the club of 400 owners. The 1406 is adequate if you don't wind that thing up too much. And the key there will be two things - compression ratio and cam, as even stock heads flow fairly well. You've already said you think it has a mild cam, which probably means it has a straight-up timing set, so let's talk about pistons. And, that's a short conversation because there's only one place to get a piston that will decent CR - Tim Meyers. But, if Tim's pistons weren't used then you are looking at about 8:1, and it isn't likely you'll be winding the engine enough to cause the 1406 to be a problem as low compression engines just don't like to wind.
Don't get me started on the Holley/Edelbrock debate. But, for daily driving I'll take an Eddy 8 days a week. Second would be a Street Demon or a Q-Jet. Racing? I could be coerced to go with a Holley, but the others will work if properly set up. (Oh, wait! You got me started! )
On the timing, are you running vacuum advance? If so, where is it connected?
What a waste - of gas and money. Gas because w/o vacuum advance you cannot get max MPG. And money because the stock DS-II ignition is more than you need.
So, w/o vacuum advance you will want all the initial advance you can get. However, the MSD doesn't have the ignition retard feature that the DS-II box does, so you can't go too far w/o it kicking back when starting. But, you want to be up close to that limit.
