Cold weather problems
Alright guys awhile back I found out that my fuel bowl heater was unplugged and presumed not working. With the weather getting colder I am having problems getting her started. I will have to cycle the keys multiple times and even then it takes a min to fire up. If it helps any the truck also blows a decent amount of blue smoke for the first few minutes of being started and usually a big white cloud with it. My dad has a 7.3 as well and he's hell bent on telling me that it's my fuel heater but I see allot of people saying you don't even need that for cold starts? I think it has to be something with the heating because once the truck is warmed up it runs fine. Bad glow plugs? Fuel heater? I'm not sure where to look. Thanks in advance
You do not need the fuel heater for cold starts, or need it at all for that matter, unless you are running in extreme cold temps. Start by checking to see if the glow plug relay is energizing when you first turn the key on. You should get juice to the 2 large posts on the relay. One should be hot all the time, bot should be hot when the key is in the run position for up to 2 minutes. If that Checks out, check the glow plugs. A quick way to check, is with an automotive test light. Clip the lead on the positive post of the battery, and touch the pin in the valve cover gasket for the glow plug. If the Light comes on, the gp is probably good, no light indicates a bad GP. The Pins in the harness are GP- injector-common- Inj.- GP. If you have a Superduty type valve cover with just 1 plug the GPS are the 2 outer most pins on each end. If you find some bad GPs, replace them with Motorcraft/Beru ZD11 glow plugs. After market ones don't seem to last, and some swell in the head when they burn out.
Received 3,118 Likes
on
For *****s and giggles, "jump" the 2 large posts on the GP relay for 30 seconds with a screw driver, being careful to touch only the 2 large posts, then try to start it. it fires up he contacts in the relay are fried, allowing juice to flow, but not enough amps to heat the gps, and the relay needs to be replaced.
on
^^^^ +1; another test to confirm this is to turn the key to RUN, and measure the voltage from each large post to ground. The GP-side post can be a LITTLE lower than the always-hot post, but if the DIFFERENCE is more than 0.3 volts, then the relay is bad. Yes, it's connecting, but not supplying sufficent power to energize the GPs.
