1970 F-100
1970 F-100
I just got my grandfather's 1970 F-100, as a Chevy guy I'm sure I will have lots of questions. It's got a 360 and an auto trans. It has the "Ranger" package. The plan is to get it running and make sure the motor is ok before going to the trans. It was parked in about 1999 because it would only shift 1-2. It would go to third occasionally, but not reliably. I will post pics soon.
flynlow8740 Welcome to and the Bumpside Forum.
I have changed my thinking over the years on these trucks. After resting for 15 years most everything drivetrain related is shot, cracked, rotted, busted......whatever. Before starting try to get a grip on "It was my grandfathers truck and I have to..." 1- keep it as original as possible, 2- modernise it, 3- something in between. Get a plan started and work the plan.
Start with cleaning and working with the sheet metal while you try to figure out the drive train. That is where I have made my biggest changes. When these trucks were built gas was at $.30 a gallon, a heck of a lot of dirt roads, with 45-50 mph truck speed limits, so there was no thoughts on fuel economy back then.
I think I would entertain a 2010 or newer power train with as much mpgs as I could get out. Some guys like the diesel conversion, I might consider an EcoBoost. The option window is wide open without restrictions in most states.
Don't rush in, you have the rest of your life to finish the truck.
John
John
on
Sounds like John's lost the faith. Surprised I didn't see an SBC conversion in the recommendation!
Don't be afraid of making power out of an old FE. You can get some serious numbers out of a junkyard build, or you can do the high performance build with modern parts. No, it won't get good mileage, but it can rock.
Getting the engine running really well doesn't mean too much if you can't (controllably) bring the truck to a stop. --brakes first then the engine.
