1965 f250 tranny swap
Ive got a very stock 1965 f250 4wd with 4sp NP manual trans and divorced dana transfer case( model 24 i believe) and looking at converting to a 3sp Automatic with o/d----Anyone have any suggestions on good transmission candidate with the least amount of modifying? Thanks
Mornin-- thanks for checking in on my post.... I'm a 1st timer... Thought I'd give it a whirl. I've got a 352 and from what I can see , the truck was offered with a HD automatic in '65, just not mine. I'd like to do the conversion but keeping it as stock looking as possible. I spoke with CJ of "CJ's Rods and machines who said he could do the steering column with the correct shifter/ gear selector for a factory match.
I've got a 352 and from what I can see, the truck was offered with a HD automatic in '65, just not mine.
Speaking is one thing, actually doing it...is another...because there is no "factory match."
Upper pic: 240/300 I-6 & 352: 1965 F100/250 4WD, 1965/66 F350, 1966 F250 4WD use a completely different engine mounting system than...
Lower Pic: 1965/66 F100/250 2WD, 1966 F100 4WD, 1967/72 (1973/79).
There is no overdrive auto that will bolt to an FE engine. I think I have seen an adapter plate to mate an AOD to an FE, but and AOD is anything but heavy duty.
EDIT: It turns out the below link makes adapters to run an AOD, E4OD (can be built into a tough tranny) as well as Chevy trannys such as the 700R4 (not the toughest by any means) or the 4L80E which can be built into a super strong tranny. The problem with the E4OD and 4L80E is that they require a controller to make them work.
If you don't mind me asking, why not run a manual?
hello113
05-05-2019 03:10 PM
Trembler
03-03-2018 11:13 AM
Eric1976mi
02-27-2018 06:58 PM
Jklnhyd
01-11-2017 10:53 AM
racer2012
01-06-2012 05:51 PM
