Brake light switch and window weatherstripping problem
Well, I can usually figure out problems on my 1948 F5 given enough time but here are two probably simple problems that I could use some help on.
Brake lights were working great but stopped. I have new everything on it. I have eliminated the wiring, lights as a possible problem. I swapped out the 1 year old switch. Still no lights. Is it possible the switch is not getting any fluid pressure? Brakes work well.
I bought the window weather stripping that goes on both sides of the glass in the door at the bottom of the window but cannot get those round clips in the holes. I just seem to bend them out of shape. There has to a trick to this one too.
Thanks in advance.
Thanks in advance.
Assuming your clips have the three tabs like mine did, here is my method for installing them.
Turn the clip sideways and press into the hole with a large flathead screwdriver. Use a small punch to bend back the 'top' tab. Carefully turn the clip to its proper orientation, and the punch the remaining two tabs back. The clip should then hold as long as you arent rough with it, or look at it the wrong way.
walrus
1999 to 2016 Super Duty
01-15-2008 11:08 AM
Crystal Moon
1997-2006 Expedition & Navigator
09-12-2003 11:14 AM
