Unknown Ford Rear/Wheels
Old 09-28-2015, 08:19 PM
towd56's Avatar
towd56
towd56 is offline
This is for you big truck guys . I just adopted this piece - saving it from the scrap yard. I know..... Anyone have any ideas on this rear end.
Old 09-29-2015, 06:53 AM
truckdog62563's Avatar
truckdog62563
truckdog62563 is offline
Marmon-Herrington Man
It's Timken, for certain, based on the split case. Single speed. My guess would be model 53566 that was used under the early F-4/5s. The two wheels pictured are not widow makers, but the concave side of the nearest one seems pretty rusted. Stu
Old 09-29-2015, 06:57 AM
jmadsen's Avatar
jmadsen
jmadsen is offline
Looks like a single speed rear axle from a 48 52 f5. Maybe f6 but i think most of the f6's had a two speed rear end.
This one probably has a 5.83 gear ratio?
Looks like a decent lockring 20" wheel also.
Other than the lockring wheels and possibly the brake drums and brake parts the rest may be scrap??
What are your plans for it?
Edit. Typing at same time as Stu. After looking again the wheel does appear to have rust around those rivets holding the wheel together. Or is that flaky paint or old axle grease and dirt? Seems thats where they tend to get bad.
Old 09-29-2015, 08:58 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Upper pic: Timken model 53566: JH = F5 Parcel Delivery / T = F5 / TL = F4 / W = F5 COE
Lower Pic: Timken model 51524: D = F2 / Y = F3 / J = F3 Parcel Delivery / JH = F5 Parcel Delivery / T = F5 / TL = F4 / W = F5 COE
Old 09-29-2015, 09:01 AM
49fordv8f4's Avatar
49fordv8f4
49fordv8f4 is offline
It could also be from a '40-'47 1 1/2 -2 ton Ford truck. The wheels are pre '48, 6.67 ratio was also common on the older trucks.
Old 09-29-2015, 09:36 AM
truckdog62563
Bill - I don't recall seeing any other reference showing the 51524 used under the bigger models. Only under F-2, F-3, and PD. I think that page sub-title is a misprint. The 51524 was also used under the earlier tonner and Studebakers.
Mark - agree that could be a 47 or earlier based on the wheels. The locking ring style, though, continued in wide use after 48 primarily on IHC and Dodge trucks. The wheels could have been a later swap. Stu
Old 09-29-2015, 10:16 AM
NumberDummy
Bill - I don't recall seeing any other reference showing the 51524 used under the bigger models. Only under F-2, F-3, and PD. I think that page sub-title is a misprint (I agree). The 51524 was also used under the earlier tonner and Studebakers.
Picture caption says one thing, application charts say another.
Old 09-29-2015, 10:31 AM
truckdog62563
Yeah, the earlier paper copies of the Chassis Catalog show the differences as does the Shop Manual. I also run into part number and size typos a lot in my wheel references, and have pen and ink corrections in many. Stu
Old 09-29-2015, 12:37 PM
towd56's Avatar
towd56
towd56 is offline
Thanks guys - the wheels are OK - most of what you see is just flake. I didn't have any plans for it other than I didn't want to see it get scrapped. It's too big for anything I have or plan on having
Old 09-29-2015, 04:28 PM
truckdog62563
If your wheels are rust free and straight, and drums near spec, you'll come out well ahead. And will be a hero to the guys looking for the parts. If you plan to remove the wheels yourself be alert to left hand and right hand threads. The nuts are marked "L" and "R". Stu
Old 09-29-2015, 08:31 PM
cstempert's Avatar
cstempert
cstempert is offline
At least check the ratio before scrapping its more likely a 6.67:1 but could be a 5.83
Should be stamped with R&P tooth count on the center housing although tough to read
Spin one wheel 2x and count the pinion
ct50f1
15
10-30-2018 01:15 PM
tractormanbill
09-08-2016 01:24 PM
HILLBILLY BOB
02-07-2015 08:13 AM
zombiefied 247
11-29-2013 08:03 PM
Jolly Roger Joe
29
07-31-2011 11:20 AM
Quick Reply: Unknown Ford Rear/Wheels
